MSI K9MM-V and CD/DVD Rom problems
CreganTur
Okay, I just got a MSI K9MM-V motherboard and an AMD x2 chipset combo.
Everything in instillation was going great up until it was time to connect the CD-rom and DVD-rom drives. I have a CDRW drive and a DVD drive and they're both on the same IDE cable. The problem is that there is nowhere to connect these drives to the motherboard that I can see!
I'm already taking up the existing IDE slot for both of my HD's- both on the same IDE cable. I have a 200Gb HD and a 4Gb backup (that I don't really use) I've also taken up the floppy port for the floppy drive.
I decided to try something and hooked up the DVD-Rom and the 200Gb HD on the same IDE cable and plugged it in. I reconnected my PC and tried to boot it. When it tried to post it kept asking me to put in my boot disk and hit enter. My XP disk was in the DVD but it would not do anything.
Should I switch to the CD/RW drive and see if it will boot from that? Do I need to change the master/slave pins when I use these 2 different devices on the same IDE cable? Or is there another way to hook up the CD/DVD drives?
basically I have no idea what to do to fix this issue. Any help would be greatly appreciated!
First make sure everything has proper jumpers that needs them. On a single IDE cable, the device connected to the very end is master, and the one 2nd to the end of the cable is slave. Once your drives are connected right, go into the bios and setup your boot order right. I usually have CD/DVD-ROM booting first, then hard drive.
... the device connected to the very end is master, and the one 2nd to the end of the cable is slave. Once your drives are connected right, go into the bios and setup your boot order right. I usually have CD/DVD-ROM booting first, then hard drive.
Okay, that's what I wasn't sure of. I do know that they are both set as master right now, so that will cause a problem.
There is still my second question- is there any other way to connect the DVD drive and the CDRW drive to this motherboard without using IDE cables? If not then I'll jsut stick with the DVD and HD on a single IDE cable.
You can get a IDE to SATA adapter so you don't have to use IDE cables. Then just hook the drives up as if they were SATA devices. You can usually get the adapters for under $20.
Do these adapters work with a normal IDE cable where I could connect both the DVD and CDRW drives into the same SATA port, or do I need to conenct them seperately?
You don't use an IDE cable at all. You use a SATA cable for SATA devices. It basically just converts your IDE device into a SATA device. SATA only supports one device on it, so if you have two devices, you will need two SATA converter boxes, two SATA cables, and two open SATA ports on your motherboard.
I'm guessing that the SATA converter boxes plug into the IDE port on the device?
so since it's single device into single SATA plug then each device would need to be set to master?
Just talked to a guy at my local small business computer shop- he's got some in stock for $15 a pop, so I'm going to go grab 2 on my way home for lunch. He told me that they would only work on HD's an dnot optical drives, and that I need to set the pins to the third option- I can't remmeber what it's called. Cable something or other.
hopefully I'll be able to get my rig working again tonight.
Thank you so much for your help w1retap, I really appreciate it!
You're welcome. I hope this works out for you. BTW, the third option is CS or cable select. :)
Yeah, that's it. I knew he said cable something...he just kind of slurred the word together so I didn't understand :rolleyes:
I just really want to get this thing up and running again so I can get back to Oblivion!:D
