MSI K8T Neo2-F raid controller...
Turbidity
I got a 250gb hard drive for christmas, this one:
http://www.newegg.com/Product/Product.asp?Item=N82E16822144417
It came without a jumper, which is passable enough i suppose. I slap some rails on it and slide it in, connect sata and power, turn on computer and, unfortunately, it doesn't show up.
Now, my windows installation and most general apps are installed on an old 60gb ide drive (W600BB) which is set as master.
Upon further inspection, when it's plugged in, the device manager shows VIA SATA RAID Controller with the error "This device cannot start. (Code 10)". When it is not plugged in, the controller has no errors. I know that the controller *can* work, since this drive is replacing an old 200gb maxtor that went corrupt (no surprises there). I've tried the following, and I can't even get the drive to show up in BIOS, much less windows:
Switch cable
Switch SATA port on mobo used
Upgrade RAID controller drivers
Upgrade motherboard drivers
Flash to newest motherboard BIOS
Also, the following:
Disconnect power to the SATA drive, only keep SATA cable plugged in, boot from ide (results in the RAID controller working as if it is not there)
Disconnecting ide, booting only with the SATA connected (goes to a 'failed boot, insert disk in a:' screen)
In addition, i've held my hand over the drive lightly as it's booting, but i've only felt minor vibrations that could be chalked up to regular case vibrations from fans etc.
Should i keep trying this, or declare it dead and RMA?
Check to make sure your Mobo BIOS doesn't have any of the SATA ports disabled.
I'd also check the manufacturer website for the montherboard, check for common problems listed in the FAQ section and see if they have a forum where other users have posted.
I'd definatly check the drive with a jumper set correctly, if needs be take it from another drive or steal one from your motherboard, some older motherboards which still use jumpers for things other that CMOS clearing are often optional (since settings can be forced in the BIOS) Or if the worst comes to the worst just use a make shift one (use your imagination)
If you cant get it setup with correct jumper configs then RMA it.
