MSI K8NGM2-NBP .. clockgen.. doesn't take settings
jmphx
Well, I broke my K8NGM2-FID (available for cheap in the FS forums! =).. I have a K8NGM2-NBP now.
I'm trying to get clockgen to work for setting the HTT/FSB over 250mhz, but without success so far. I can move the sliders, but when i hit "apply", nothing happens.
I can change the PCIE and PCI bus speeds with clockgen, and when I hit apply there, it takes the settings (but of course i move them back right away).
clockgen is listed as working with the -FID on the anandtech 'official' k8ngm2-fid forum thread. Being such similar boards, I figured clockgen would work on the -NBP too.
Anyone had success getting >250mhz on the -NBP? If so, how?
Have you set the proper PLL IC? Take a flashlight and look around for a rectangular chip near your CPU socket. Make sure the serial number listed on it is the one that's selected in ClockGen.
Clockgen doesn't even give me a chance to select the IC. It says Nvidia C51 (IIRC, i'm not at home to verify at the moment), and it's greyed out, so I can't change it.
Yep, confirmed. clockgen v1.0.5.0 .. in 'PLL Setup'. The IC shown is 'nVidia C51'. And I can't change it. Hitting 'read clocks' does nothing either. sigh
Only other version I've been able to find so far is 1.0.4.7. This ver sees the CG IC as "nVidia 6100", but just like clockgen 1.0.5.0, it does not take any settings after hitting 'apply'.
Any other apps out there that are useful for changing HTT/FSB speeds?
I'll go bug the clockgen devs on their own forums to see why clockgen isn't working on this board =) thanks guys
