MSI K8N Plat; error loading operating system HELP!!
HeyImLance
So ive got this msi K8N Neo Platinum here and everything powers up and works, I goto install winXP, use the disk for the sata drivers, i format the drive and make my partitions which all works just fine, then i reboot the system to go into the actual windows xp install process and i get the "error loading operating system" error. Anyone have any idea what the problem might be?
Im using the latest msi bios and my setup along with the board is...
a64 3400
Samsung SP1213C - 120gig sata
1gig corsair xms 3200c2pt
i am having this same problem...
i was reading somewhere that it could be because of the default auto settings on udma for the hd...they said to disable udma for the install...
i'm running it right now...we'll see if it worked.
well that didn't work...now the other solution that i heard about... setting it to 100 instead of auto...
btw... this is using an xp pro (non sp1, sp2 cd) -- i'm also using the xp ata controller disk that came with the msi board.
this stuff is frustating.
kingston 3200 1 gig
wd 100gb (i have two, but i unhooked one of them to not make winxp confused)
amd 64 3000+ (clawhammer)
msi k8n platinum neo
alright,
setting it to mode 4, with no udma doesn't do anything.
fdisk /mbr doesn't do anything but make "missing operating system" error
changing jumpers from CS to m/s doesn't work.
this is rediculous!
please, someone help...
i can't find anything on this, anywhere that has given me the answer.
alright, here is another idea that i came across in my searchings...
set the hd to LBA or Large (depending on what works or not)...this seems to have helped many people.
Unfortunately, I'm at work right now and can't get to my computer to test it out.
Luckily everything works great with gentoo...wow...it's blazingly fast with the new amd64 gcc options. Hey, if xp pro just doesn't work, you can always install linux like me and tinker with xp while you have a working machine!
I also saw that the HD could just be having trouble spinning up in time...but, i think that's bull since it takes a while for the system to fully post when you have the XP cd in the drive and don't hit the "any key".
let me know if this works for you.
I had some of the same problems with my ECS k7s5a...ended up being my keyboard that was causing it.
I know it sounds odd, but with the kb I had I couldn't do shit..had to use my old one that's a million years old. Thus, to this day, I keep an old keyboard handy...nothing special about it either, just an old dell KB :D
alright...i fixed my problem...
changing the access from auto to LARGE worked. yes!
let me know how it goes for you.
