MSI K8N Neo4 SATA setup
Krispy Kritter
OK, here's the story. The MSI K8N Neo4 Platinum that I'm running in my file "server" has 8 SATA ports. So far, I've only been using SATA1-4 which are easily setup in the BIOS to resemble IDE drives. Just enable the port, connect a SATA HDD, and you're ready to go. I'm now trying to add another HDD using one of the remaining SATA ports, labeled SATA5-8 in the manual. Can these be setup and used for single drives, or are they RAID only? If they are RAID only, what's the easiest way to setup and use them? I've never used RAID before and I'm not looking for performance or redundancy, I just want to add another HDD.
Thanks
You don't have to use RAID. Set the BIOS's SATA mode to "IDE" or similar.
I see settings for that for the nvidia chipset (which is SATA ports 1-4). For the Silicon Images chipset (SATA ports 5-8), I only see options for RAID on/off. With it on, it wants me setup RAID, with it off, the HDD isn't recognized.
Anyway, from what I've read today, you can only used RAID on the SI controller. So with that being the case, I'm considering using RAID5 for my storage "drive". I was considering it anyway, just wasn't ready to spend the money on the remaining HDD's at the moment. So, any known issues or pitfalls using the SI controller for RAID5 on this MB that I should be aware of? I'd rather not also lay out the cash for a PCI RAID controller card, but if I do, I will.
OK, the fun begins (ie: it doesn't work). I have the 4 HDD's connected to the SI RAID controller. The drives are recognized during bootup by the BIOS. Within XP I've used the SATARAID5 GUI to create a RAID group. The group is created (which took like 36 hours), active, and available. I should now be able to go into Disk Management, activate, partition, and format the drive for use....however, the "disk" isn't recognized. I've obviously missed a step somewhere or I have a software/driver/hardware issue. I have noticed that in Device Manager, my "disk" is listed in the "hard drives" section. So what gives? Anyone have any suggestions or ideas?
Update in case someone else ever needs guidance:
After contacting MSI support, I had to do more research on my own. MSI support stated my problem was because the SI controller is a SATA 1 controller and doesn't work with SATA HDD's. Which obviously is incorrect because the HDD's are recognized and the GUI is able to configure and create the array.
So I purchased a Rosewill RC-217 which is basically the SATA 2 version of the SI contoller on the MB. The drives were recognized and 33 hours later my RAID array was created and active. After a quick reboot of Windows I entered Disk Manager only to find that the disk is not recognized.
So more digging and research on web reveals that the problem isn't the RAID controller (either one of them), but the fact that 32 bit Windows won't recognize a disk over 2TB. So I dropped a HDD from the array (I am using 4 1TB drives) and created a new RAID5 array using only 3 HDD's.
