MSI K8n Neo4 Platinum
jnick
Someone from the forums thought they heard that a 7800GT or 7800GTX will NOT fit in a MSI K8N Neo4 Platinum (non-SLI). They weren't 100% sure so I was wondering if this is true or not?
I wasn't sure which forum to post it in (Video Card or Here) so if a mod feels it needs to be in the Video Card forum, I'd appreciate it if you could move it.
Cheers.
Cheers.
There was an issue with earlier revision boards where the GPU fan power connector contacted some capacitors right next to the PCI-E slot prevented the card from fully inserting. These cap's could be gently pushed slightly apart and the power connector would fit between them and the card could be slotted in fine although some people don't like the idea of spreading capacitors..
MSI however offered for people to send back boards if they had this issue and they would modify them to correct the issue. As far as I'm aware the board design has since been revised and there should be no current issues.
It basically came down to a change with the card design and MSI didn't seem to know that the Nvidia GPU design had the fan connector where it ended up being.
All was good in the end!
