MSI K8N Neo4 Platinum problems
microxp
just got my neo in and hooked everything up, fired up the computer and i'm stuck at the platnium screen. i can't hit tab to post or del to enter the bios setup. i'm using a usb keyboard and mouse, and i've also tried a ps/2 keyboard and it still doesn't work. i did a google search and came up with a crap load of problems with this board. i tried messing with the cables and etc... first time this has ever happend to me. this is my 2nd board from msi. i'll probably be ordering an asus board tomorrow. what should i do and what board so i go with?
here's the system i ordered
AMD Athlon 64 3700+ Processor (San Diego)
MSI K8N Neo4 Platinum nForce4
MSI NX6800GT-T2D256E GeForce 6800
Corsair TWINX1024-3200XLPT
160 gb hd my friend gave me for christmas
using my old plextor dvd burner
using my old audigy 2
do you have any other sticks of memory ?
You might only need a bios update to correct your problem
ok, i just gave it try with diffrent stick of ram and its still saying 1024 and i can't use the keyboard or anything. one strange thing i noticed i have like two seconds to press tab for the post before it sits at the platnium screen. when i do press tab it finds my processor, but it seems like the board is having a problem with the memory for some reason.
this guy has the exact same problem i do
http://forum.msi.com.tw/index.php?topic=80086.from1116398540;topicseen
It would be very helpful if someone who owns this board would step up and try to help.
When you cleared the CMOS, did you remove the battery or did you leave that there ? Was the PSU still plugged in ? Seems like the problem you have might have nothing to do with the keyboard or mouse since ps/2 or USB give the same result.
Try removing everything except for the video card and cpu and start from there ...
I only had that problem on mine while trying to OC with unstable settings. clear the cmos, use the ps2 and set the bios back to default. then install a new bios. You are using the green ram slots?
keep playing with it, Im running a 3000 venice and 4x512 twinmos riht now.
Code:
http://www.ocforums.com/forumdisplay.php?f=46
nate
i took the battery out, pushed the button, etc.. i tried green and purple slots. nothing happens.
I have the same board running with a 3200+ Venice and two 1GB sticks. It's booted from the start without a BIOS flash, which I'm almost afraid to do, as I have no problems.
Sorry this isn't much help...if you'd like me to dig around for any other info, just let me know.
i had no probs. bootin with the older bios (without flashin) with the neo platinum 4 sli and i have the 3700+ San Diego as well...dont see what the prob could be...hows ur power supply?
I have this problem, but hitting the reset button gets me in fine afterward. Does not happen all the time. Seems to happen more off a reboot as opposed to a cold boot. It seemed to happen more when I was using an older CDROM. I flashed the bios this morning and am crossing my fingers the problem goes away.
Seasonic 500watt psu
2 sticks corsair
San Diego 4000+ athlon
