GaleForce
- Aug 7, 2004
I just built my computer, but I'm running into a bit of a problem. I have a WD Raptor 10k RPM SATA drive. There are two SATA connections on the mobo, should I use the upper or lower one? Also, I have two optical drives, a DVD-ROM and a DVD RW, obviously IDE. Should I plug that into the white port or the blue port on the mobo?
The reason I ask is the system posts and everything but up on the screen it says "Media test failure. Check cables."
Quick assistance would be most appreciated. Thanks!
