I have been looking into upgrading my enermax 465w ps but I haven't received my new motherboard yet which is the MSI K8N Neo2 Platinum. Can anyone tell me if it requires a 24pin or 20pin power connection plug? Thanks.
Although this doesn't directly answer your question, I recommend you get a 24 pin connection PSU and then get a 24 pin to 20 pin converter for your motherboard if it's not 24 pin. This way it's at least semi-future proof.
