Acidwarp01
- Jan 23, 2003
I bought an MSI K8N Neo-F motherboard, a AMD64 Winchester 3200+, and a 6600GT PCI-E video card. Setup went fine, until I started to install Windows XP. Everytime I would try to set windows up it would eventually freeze. After 3 attempts I got XP installed, but it would still freeze. Seemed to freeze mainly when I was trying to install something from CD. So after going around and around and trying numerous things. I decided to swap out my memory. I swapped out two OCZ 256 PC3200 for 1 Muskin 512 PC3200. Problem seemed to stop. I know the OCZ are good, I ran them for about 8 months on my old rig with no issues at all. So I placed the OCZs back in and made the memory timings match those of the Muskin. The muskin runs at 2.5 3 3 8 and the OCZs run at 2 3 3 6. They ran fine for a few hours, but then the issue started again. So now I am back on the Muskin and things "seem" ok. Does anyone have any idea what could be causing this? I will list my specs below. Any advice, help, anything is greatly appreciated.
Specs:
MSI K8N Neo 4 - F Motherboard
Lite On SOHW-1633S DVD+/-RW DL
Maxtor 60GB 7200 RPM IDE Hard Drive
WD 80GB 7200 RPMM IDE Hard Drive
Chaintech 6600GT PCI-E Video card
512MB Muskin PC3200
Specs:
512MB Muskin PC3200
