MSI K8N Diamond Plus Power Question
klopper
Hey,
I recently ordered this motherboard, and was looking on Newegg on some information about it, and it stated it needed a Power supply with a -5V pin. So I checked the Power Supply I ordered, the Rosewill RP550-2 ATX 2.01 550W Power Supply, and it doesn't say anything about the -5V pin.
Will this be a problem with the board?
I had the same question. And from what MSI's site says, yes you do need it.
Refer to this thread I started about it. Take the last reply by HighTest and make your own decision about his remark on the Chip replacement. I personnally just got the PSU that had the -5V pin. If the manufacturere says it's required then it is required IMO. I would Return the PSU you have and get one you know has a -5v Rail.
Well that kinda sucks. Would the audio just not work or would the board not function?
Also, what kind of PSU would you recommend then?
The Audigy sound won't work.
I bought the OCZ ModStream 520W. It has the -5v Rail and the Modular input. It's a nice PSU and it got good reviews. It's a bit pricey though. I didn't want to spend as much as I did, but I have piece of mind as far as a Power is concerned.
