MSI K7N2-Delta L max FSB
P3N1X[H]
quick question for any MSI K7N2-Delta L owners...
i have my 2500+ OC to 3200+ by just uppin the fsb to 400mhz. simple enough OC. well i got some mnew meory that will go past 400mhz no problem. so ii bumped it up to 210mhz for a quick run. and im havin a bit of stability issues. but i know the memory can handle it
http://www.newegg.com/Product/Product.asp?Item=N82E16820146355
so ive got the memory set to 2-2-2-6 and my fsb to 420mhz (hehe 420) and my cpu is at 1.675v all seems well, but i get some crashed, and hangs. thast when i upped the vcore to 1.675 up from 1.625. anyways. im wondering whats the max fsb this board can take? since its only a 400mhz chipset(i have a fan on the chipset to keep cool) the bios allows increase on the fsb to 235mhz i believe it was. so if the boios allows it, i know the board might not be able to support it..i relaxed the timings on the memory as well to 2-3-3-7 but similar problems arose.
so im asking all the K7N2_Delta Owners how fast they got their fsb up and by what means..
if this is the wrong forum please move this. i know its about overclocking, but its about a specific motherboard overclock than it is about overclocking in general
I have one and experience the same problems. Up to about 215 is fine when I run memtest, but Windows will give bluescreens. 220+ generates about 50,000 errors on each pass of memtest. I have TwinMOS SP with a Booster, and no matter what voltages/timings I use, the same stuff happens. It won't even POST if I try to use a divider.
I'm looking to replace the POS. Might finally go to A64.
It's just a socket A thing. There are no socket A chipsets that really are very comfortable above the 220fsb mark or so. The only exception I can really think of is the DFI NFII Lanparty B which I've seen up to like 250 or so. My A7N8X Deluxe 2.0 would also flake out above 220, back in the day.
