MSI k7n2 Delta - L locking up
comicbob
I accidentally set the cpu to 200 x 12.5, and then my comp wouldnt boot. I rest the cmos and booted in safe mode, reset everything to stock, went out of safe mode. The usual reset. Anyway, now I cannot keep my computer on for more than 5 minutes without it locking up. It can be idleing and it will lock up. I get no indication that anything else, ie the cpu, ram, video card is damaged because it boots just fine. Im thinking I damaged the mobo and need a new one. Any opinions?
When you were setting the fsb did you set it through the bios or through the jumper on the board that sets between 166/200. If you still have problems take the J11 or J10 jumper not sure look in the manual, and put it to the safe mode(100fsb) and see if your computer is stable then. If it isn't then it may still be overclocked and that may still be causing the problems. That board can be a b*tch to set up but once its running its great.
Its not still overclocked. I have set and rest everything and evern underclocked the cpu to under 1gHz, but not matter what it does the some thing. I agree, this board is great when it works.
Already did. I have the lastest bios on my machine. Also got the latest motherboard drivers. Maybe loading old drivers will help. But then again, maybe not.
Hi, how did you flash your motherboard?
I just got myself this board again it is claimed to be working.
I put it in my case with my 2800+ barton which for some reason detects as 1250 mhz and not the speed it should be which is like 2083 mhz. It is also detected as this stupid speed by my ASUS A7v8x piece of rubbish motherboard.
Thing is i dont know what i am doing and i see the post boot up and i can navigate in the bios , its all working no freesing, but as soon as i try to boot on my hard drive whjich is the old windows xp setup one used by my old setup on the a7v8x-x board, it then hangs with those iwndows boot options like safe mode or whatever and it counts down but i cant press enter or move the arrow up and down and it counts down from 30 seconds to 0 and does nothing, it is like it has locked my keyboard.
Any idea what is wrong?
I hope the motherboard is not broken or faulty
The barton core CPU should be running at 166 front bus and you are running at 100. 12.5 x 100=1250
Okay so how do i set it?
It is indeed a 2800+ no idea why it says 100.
It does this on the ASUS A7V8X-X and the MSI K7N2 Delta-l which i have
I guess i need to manually set the speed?
But, can i just use it for the initial setup of my computer, on 1250?
You can run it all the time at 1250 if you want. It has been a long time since I've looked at one of these boards but the front side bus can be changed in the BIOs. Probably in the advanced section. You may have to set the CPU settings to manual from auto.
Go into the bios and set the fsb to 166. Most boards default to 100 or 133 if a nes chip is installed so it doesn't oc the new chip and do damage. The Fsb is not locked on axp's just the multi. on most. Your board is fine if it is even posting with the chip installed.
^^ good call. I recently rebuilt a machine with this board and it for sure defaulted to 100 when I reset the bios. Also make sure the ddr timings are correct... mine would get a bit screwy after a cmos reset.
Hi, so i finally got this board on ebay , runs good and whatever.
I have 1GB of ram which sucks though:
DDR 400 3200 OZC 2-3-2-5 512 meg x2
I bought Kingston recently x1 1GB 400 3-3-3-8 and plugged it in, no issues, windows working great and whatever.
I dont know, its been 2-3 weeks maybe and now the b1tch computer reboots all the time.
I dont bloody understand what the hell is going on.
My hard drive i believe is not funny, thought it is Partitioned in 3 parts.
I have fornated C:\ and installed windows XP --- but as soon as XP is almost done... example loading windows for the first time and as soon as it enters "applying windows settings" or whatever then it bloody reboots.
I have tried to install windows 7 also and it doesnt even manage to copy the files in the installation , i think it got to 60 or 30 odd percent.
Dont understand.
I have run MEMTREST86+ on the 1GB and it seems fine and also my 512 stick independantly, also seems fine (i only ran 1-2 passes.)
hmm, when i run my machine with 1GB stick kingston alone in slot 1 or 3 for example the machine is fine.... windows xp installed and works....
I tested this with the normal old setup i had i.e. the x2 512 meg OCZ's and its fine also , windows does not reboot.
I decided to flash my bios from the 4.7 version to the 4.9 version i think it is, the latest one.... no bloody idea, but it is reboots, i dont freeking understand what the hell is wrong and why the PC was fine at first with all the sticks, and like now its giving me sh1t.
I just dont get it, is it maybe some bios setting which i HAD on and not off ?
I know the only thing i may have done funny between the time when it all ran good with all my memory (2GB ) and until my reboots was i had loaded bios defaults.... i know that loading bios defaults DOES NOT always restore everything.... some values stay as is.
Would a Jumper.... or Bios Battery-take-out help? or i dont know.... bloody heck, somebody who is cleverer than me can only tell me.
Clearly i am not that smart here.
I just dont understand why or how technology can do this to people sometimes.
All help will be appreciated and the one who can give me a answer , i will send you a gift . :) really. ... thats isf you want . I might send you rare money or something.
Thanks.
so it's got to be the other memory, the kingston? maybe the board just doesn't like it... mine loves ocz 2-3-2-5 modules. never an issue
Its just funny or bizare that the bloody thing was fine at first and after a week a swear or even 2 or 3 it reboots nowm i mean its doesnt make sense?
is there some setting in the bios that i can try maybe? i dont know what that..... like in the bios u get things that say , like Spread 0.5% or whatever, i dont know hat that stuff is, i mean i dont know , maybe there is something i can enable or disable in the bios.... i mean i dont see how Ram can like "kinda" get funny.,,.,. or is it possible? i mean i reall honestly say, it used to work , and it was on for long , the pc, but like then after 2 weeks at least maybe even 3 it decided to reboot.
I'm confused. It was working with the OCZ ram, but not the Kingston and now that you've updated the BIOS, it doesn't do anything buy restart?
It might be time to start looking at a little newer tech. Maybe an Athlon 64 x2 or a Core 2 Duo. Nothing crazy like a first gen core i7 tho.
No, read the entire thing i posted man, i basically had 1gb (2 x 512 megs PCZ) thats it.
Then i bought the Kingston 1GB stick and i plugged it in and at worked ... for at least 2-3 weeks and i left it on over weekend no problems... listening to streaming audio and whatever.
Now it is cooked.... and im saying that the only thing that i did was load bios defaults thats it.
I am not bloody sure what is cooking here.
Still confussed?
Yeah, I'm trying, but your typing is like stream-of-consciousness gibberish - no offense. I understand you now though.
First thing I would do is check your RAM in another board to make sure it is fried. Then I would check your PSU to make sure it's putting out good power. Then I would check a new set of RAM in this board. I remember toasting a couple of sticks of DDR400 with a bad PSU on my K7N2 (circa 2003).
That is a really old board, and if you got it on ebay, there is no telling how it was abused. The board could just be toast.
"but your typing is like stream-of-consciousness gibberish "
Yeh usually some dont understand me here at home too, i dont know, i might be special who knows, ill try to be as precise.
Okay so hmm, not sure now man, its just bloody weird.
I dont get how it is fine with 1GB my system does NOT reboot,
Whether it be the 1GB Kingston or the OCZ 2x 512 megs.
flip this
hmm, if i put all the ram in and in any slots, it bloody reboots, its just weird, i have tried to re-install as i mentioned - no good.
Im just sad, i mean i swear i did use all the ram at a stage it was perfect for like 2-3 weeks , surely. and then i dont know, its just stuffed.
how in windows can i see logs or whatever , do u get programs or whatever to trace errors?
The reboots, do u think i should remove my DVDROM and just have my Mainboard Bios Defaults on and all Ram in and Hard Drive and BFG 7800 AGP Card and try maybe reseating my Molex connectors ?
I do know that i have had issues in the past --- like for years with Molex connectors on this system , like i would have to twist the wires 1 or 2 turns and then plug it in to the devices...if u get what i mean? .....though the plugs seems to be fitting niely...i guess?
Hmm, maybe like u say , when I use 2GB it uses more power? and it can be that slight power that i am using that can cause reboot? and or also.... a device's molex might not be firmly secure.... exmaple the screen card or the ide hard drive...thats all that i have here that uses the molex.....
i will take the DVD rom out of the equation...
Is this the next test i must try?
revenant , would you be able to get me OZC ram ?
ebay is your friend. OCZ btw..
also... just run two memory modules, same speed and timings and size. you'll get the best stability that way.
ebay is somewhat my friend, there are guys charging ridiculous amount for shipping , and some use USPS intl standard and charge one price and some another, it makes no bloody sense
Im willing to pay 15 USD for shipping because i believe that that is the correct price.
Thats with tracking as well, i know it is real, i dont know where these guys come up with 38 USD or 40 odd USD , they are nuts
you just gotta stay on the hunt and jump on stuff with free shipping, etc..
Okay ill try, i have tried for a while, i mean i can go as max as 50 bucks for ram, really .
with my exchange rate it is pretty expensive.
thats why i have a dinosaur computer.
