Hey guys,
So lets start out by this:
Intel i3-540 processor
MSI-H55-E23 Motherboard
My issue is, the VGA port works 100% fine. The DVI port on the other hand does not. This happened with a total of 3 systems (all do not work). And all are the same spec. The i3-540 has the integrated Intel HD graphics on it, but for some reason, no DVI.
The VGA will work, post, goto Windows, run normally. The DVI won't even show post or bios screens (computer boots normally, just no signal).
Any ideas? It shouldn't be a driver issue, because it doesn't even show post (before drivers are loaded).
We had reset the bios back to default, and reseated all components. Tried several different monitors to no avail.
Let me know if you got any recourse for this.
