MSI Eclipse SLI not working.
rdz5008
I have an x58 eclipse with an i7 920, 6 gb of ocz tri-channel (3x2), and a radeon 6970 video card (also a geforce 8800gts)
My computer started acting very funky... random freezing, would hang at the BIOS (with 423c on the bottom right of the screen) and it eventually (last night), quit working at all.
The computer powers on but I get no screen. The motherboard blue LED's are all lit up, but the monitor won't light up, and the DLED will not give me any information as to why it won't turn on. The CPU, however, is generating heat. Here's what I've tried so far:
1. Remove HSF, clean, reapply thermal paste
2. Reseat RAM
3. Try every possibly combination of RAM sticks in each slot
4. Tried swapping out my 6970 for my 8800GTS
5. Reseated my CPU.
6. Tried a different power supply
7. Breadboarding. (removed motherboard from case, set on top of cardboard box, attempted boot with new power supply, both video cards, ram swap, no hard drives connected)
8. PC Speaker: 3 long beeps after a few second delay. (AMI Bios)
I've examined the board for burst caps, any sign of death on this thing, and I can't seem to find anything that might be physically exploded (i've had a cap burst on a motherboard before, that's a spooky time Shocked)
man it kinda looks like a motherboard amy have bit the dust...that a shame if it has as that is a high dollar board...hopefully you still have warranty...
have you tryed a cmos clear...battery out, jumper set to clr?
I know from reading seems like all the msi x58 boards were hot running with the stock tim...if you get another board through rma might be a good idea to reseat heatsinks using good tim and add active cooling on the northbridge...good luck guy, and hopefully you have warranty still left..
I'd reset the CMOS and put only one stick of ram in the farthest memory slot from the CPU. This usually works for me.
