OK, so I am looking for a X-58 1366 board that does 2 things.
1.) Runs turbo mode on a i7 920 on all 4 cores 24/7 (my current P6T v2 does)
2.) will allow me to run 2 480 GTX's @ 16 x mode, while having 2 1x sound/nic cards installed as well.
So I found the board below:
http://hothardware.com/Reviews/MSIs-Big-Bang-XPower-X58-Military-Style/?page=5
THis board seems to be on point, until i read its PCI-E SLI config chart. It is very confusing, and I dont know if this is refering to videocards, or just add in cards all together. If its refering to add in cards, then my 2 480's will be running 8x 8x and that is not acceptable, even though i know there would be minimal loss. Can someone confirm if I can run 4 cards in 16x 16x 1x 1x mode?
I was looking at the Asus SaberTooth, but very little info about it out there, and not sure why its so cheap. Like the board above cause its 16+2 instead of the 8+2 on the sabertooth. I know again that wont make a huge difference, but I like having the 16+2 if i had the option.
