MSI Afterburner Question
Endurancevm
I am running dual monitors on my GTX260 and obviously the driver wont allow it to downclock in 2D. To remedy this, I have MSI's afterburner where I have forced 2D clocks the lowest they will go, however the app won't allow me to go lower. For example, I want to run my GTX260 at low-power 3D/2D clocks of 400/800/300 @ 1.025v and it won't allow me to go that low(the lowest it goes is 465/971/810. Core, shader, memory).
I was wondering, is there a way to edit a cfg or something that will allow me to set custom bottom/top thresholds for clocks?
I know to exceed the lock on my XFX 5870 I had to edit a file in the directory. It may be the same for your issue.
Look for the MSIAfterburner.cfg file and then at the bottom you will see this line:
EnableUnofficialOverclocking = 0
Change the 0 to a 1 and save it then try your tweaks again.
good luck.
P.S.
I rushed through this (A bad habit.) and when I went back to double check, It's listed under:
[ATIADLHAL]
So, I am not sure if applies to specifically ATI or if it's simply coincidence. (I hope it works for you, apologies if not. Oops, my noobness is showing.....:eek:)
good luck.
P.S.
[ATIADLHAL]
Unfortunately that doesn't do anything for nvidia cards.
I tried going into my profile cfg and manually setting memclock to 300, but upon loading the profile in afterburner it sets the memory clock to stock(1200).
