Bluesun311
- Sep 21, 2013
linky
I tried Precision X... it causes problems for me in browsing and general OS weirdness. This program works.
Change note:
Added optional unified GPU usage monitoring path via D3DKMT performance counters. You may tick Enable unified GPU usage monitoring option in AMD compatibilities properties in General tab as a workaround to replace native AMD GPU usage monitoring if it is working improperly (e.g. broken GPU usage monitoring in AMD ADL API for AMD Sea Islands GPU family)
Added basic monitoring for unsupported GPUs (e.g. Intel integrated iGPUs):
o Now GPU usage and videomemory usage can be monitored and displayed in On-Screen Display on any GPU, so you can use MSI Afterburner to monitor graphics subsystem on laptops without dedicated NVIDIA/AMD GPU
o Extended GPU usage monitoring for Intel integrated iGPUs. You can independently monitor usage of main GPU execution unit (labeled as GPU usage) and MFX unit (labeled as "VID usage" to keep NVIDIA-styled GPU domains naming)
Added NV12 compression to the list of available video formats to Videocapture tab. This format can be used to replace uncompressed video recording with fixed 2x compression ratio at the cost of some color information loss caused by RGB to YUV 4:2:0 color space conversion
RivaTuner Statistics Server has been upgraded to version 6.1.0
