MSI A7N2 Delta2 - WinXP Issues
nalorin
Hi, I've got an MSI A7N2 Delta2 that is an -FSR, i believe (since it's red, and not black).
Now here's the issue:
I'm running WinXP Pro, SP2, and every other time that I reboot, my computer will install an SMC1211TX network card over and over and OVER again! - it keeps going - to 30 or more
The only network cards I have in my computer are:
1) Realtek 8139B PCI 10/100 NIC
2) NVIDIA Nforce Networking Controller
I tried disabling the problematic driver in Device manager, but that did nothing - it still installs repetitively
And I can't remove any of them, because I get the error message (even in safe mode w/o networking support) that basically says that it could not remove the device, because it may be required to boot your computer.
Now, i've fallen a little behind the times, so i'm not up to snuff on what chipset the onboard network uses, but I definately know that the realtek doesn't have any SMC components.
Any suggestions on how to fix the problem of the Haunted NIC Driver?
One other interesting point to note, is if I restart the computer, and look at device manager, they're all still there (all 30 copies of the NIC driver), but if I look again a few minutes later, they're gone... and if I restart my computer again, it will sometimes start reinstalling the 30, 40, 50... copies over and over again until I shutdown the computer again...
PLEASE help!
