MSI 875p Neo and Sandra temps / memory overclocking
Dethtoll
I have a few questions, and I guess this fits more in this forum than the others...
1.) I have the above board with an Intel P4 2.8Ghz 800mhz FSB. The MSI CoreCenter utility and Sisoft Sandra both agree on the CPU temp (35c - 40c) and the System temp (30c - 35c). However, Sandra has a third temperature under the Mainboard Information module - the 'Power / Aux' temp, which reads 55.5c during idle. What is this temperature reading? Is it the temperature of my power supply? My case is cooled fairly well, and even the hottest of components feel only slightly warm to the touch. The exhaust on my power supply (350w Antec, BTW) doesn't feel warm at all, and the unit itself is cool to the touch. I don't see what could possibly be running at 55.5c.
2.) I've had this system for a few months now, and I've been using a stick of Corsair's DDR2700 from the start. I noticed recently that the minimum FSB for the P4 800 is 200 mhz, which shows 400mhz for the DDR speed. Have I been overclocking my 333mhz memory to 400mhz all this time? During POST, it states the memory speed is 400mhz, so I'm guessing this is the case. Could this have something to do with the aforementioned high power temp? The memory feels only slightly warm to the touch. I was even running a 215 FSB for awhile, with no noticeable increase in any temperatures. Should I be running DDR3200, or am I just completely confused about the relation between the FSB and memory speeds?
Thanks for your help guys!
This thread wasn't too popular here :rolleyes: , so I reposted it in the overclocking & cooling forum
