I finallllly found the problem to my start up problems, but need help with a solution!
Here's some background:
I have an AMD AM3 Phenom II x4 945 with an MSI 870a-g54 Motherboard. (no OC)
Patriot ddr3 1600 2x2gb memory and for some time now if i were to shut down my computer for more than a few hours, the start up into Windows 7 x64 bit version would crash several times (all errors were random, but usually referenced either a driver or a memory dump).
I tested everything, and everything came back clean, but recently I thought I'd disable the USB 3.0 controller that came with the board. I shut it down for the night, and viola, it started up normally.
Anyway, I'm wondering if anyone has had this problem and if they have come up with a solution. I havn't flashed my bios (have the janurary 2011 one), but i uninstalled the drivers.
Look forward to hearing from you guys, thanks!
