Hi yall i need help,
I have just removed my big cooler on my MSI7900GTO,
because it would't not fit in my rig.(no room)
So i put a zallman H2O cooler on the card gpu and On my mem chips are the bleu heatsinks from the zallman kit.
In the sidedoor of my rig are 2 Tytan 90mm alu fans just in front of the waterblock,in de back of my rig is a 12mm tytan alu fan who sucks all the warm air out.
The 2 Tytans inthe sidedoor are blowing fresh air in the Card it self and 2 9mm Tytan fans in de front of my rig also blow fresh air in the case.
Then my coolingwaterreservoir stands with my pump in a small fridge with ice packs and a peltier for extra cooling.
After de pencel mod it started acting strange.
My Gpu coretemp is around 46 degrees and after,intens gaming or something else my machine just locks up and/or reboots.
I dont think there is anything wrong with my H2o install or de Vmem mod.
But as i said before i had to remove the big cooler and replace it with H2o cooler from Zalmann.
Can it have anything to do with the fact that there is no fan conected on the printboard,and the card just assumes that its to hot and shuts it self down
In the debugwindow from NVidia forceware,i got the same warningmessage about 20 times and then it just stopt???
I started up everest and there it was the fan shows up under the graphicsadapter,showing a full working mode off 100%.
The funny part is,that the Coolingfan still sits in his box,and it is not even connected to the graphboard itself.
Has anyone have the same problem and could you all help me with this problem....Thanks Allot.
Is there a way to turn it off via bios flash a proggie or something ,Its driving me mad.....
MVG..........P0p
MVG..........P0p
