MSI 785GTM-E45 Undervolt?
Mermalion
Hi guys :D I've been posting quite a bit about this new rig and I hope I'm not bothering anyone.
Since I built this new rig my GF has done nothing but b**** about how hot it makes the room. I would love to be able to undervolt the CPU if at all possible but this seems like it's not able to be done. In the Bios there is no option to adjust the CPU voltage ( Unless I can unlock hidden options?? ) but it does show the CPU voltage and it sits at about 1.4v IIRC. I tried using RMclock to adjust it but it doesn't show anything for this board. I also have the MSI Overclocking Center installed and it doesn't have a CPU voltage option either.
Under "over voltage" I have the option to change the ram, NB, and SB voltage. The lowest for NB is 1.131v and SB is 1.230v. The ram can go as low as 1.8 and it seems to run fine at that. Does anyone have any suggestions as to how I could undervolt this processor? or does anyone else have this board that could tell me if I can or can't do this?
Any help is greatly appreciated guys... Thanks!
