Let me preface this by saying that I have already purchased one 6600GT from newegg, which ran at 82 C+ while testing the card with World of Warcraft, until the card subsequently died from overheating while I was running a quake 3 timedemo at max details and full anti-aliasing/anisotropic filtering. So, I RMAed that card, and I have received a second MSI 6600GT.
In early testing with World of Warcraft I have found that this card runs slightly cooler than the previous card generally, at around 75-76 C most of the time, but when I enabled 8X anti-aliasing and max details, I noticed that card spiking up to 80 C. I have turned off the AA and filtering since then since I am afraid of what may happen.
When i took the new card out of the bag, I glanced at the cooling connection, and it looks to me from the outside that the thermal tape looks kinda crappily connected, possibly even slightly torn. So, my question is, what should I do? I've already RMAed one card, and I need to decide what I'm going to do with regards to this one. Should I remove the cooling unit, remove the thermal tape, and then apply some thermal grease instead? If so, what brand of thermal grease should I use? Would doing this noticably void my warranty if something were to go awry?
My second option I guess, is just to throw everything possible at the card, max AA and details, and just see if it can hold up over a prolonged period.
If anyone has any advice as to what I should do, I would really appreciate it, I'm not sure if Newegg would let me RMA the card a second time. Thanks for any responses.
