msi 2 neo plat
Aminotaur
hey all, i just got my crucial pc3200 running in dual channel mode, (green slots) now why cant i use my previous 512x2 in the purple slots? i had 4 ram sticks in their before, it's not really a upgrade unless i can put my other two 512's in the purple slot's anyone know the problem? thanks
Firstly,
Dual Channel on this motherboard is achieved with your memory in slots 1 (Green) and 2 (Purple) or 3 (Green) and 4 (Purple).
If you've inserted your's into both green slots your not running dual channel.
Secondly,
Read and understand this if you still want to use your old 512's.
http://www.msi.com.tw/program/products/mainboard/mbd/pro_mbd_detail.php?UID=607
I personally would have grabbed 2 x 1GB dual kits (Tested + Certified) and made sure my ram was all matched (same brand, speed and latency etc) otherwise your likely to run into issues especially if your overclocking.
