MSAA and SSAA
bigbeard86
I have been playing BF4 using 16xEQ SSAA using CCC and had the in-game AA option set to off. Out of curiosity, when I turned BF4 AA in-game to 4xMSAA I lose about 20fps. How does this work? are my gpus pushing SSAA and MSAA at the same time? is it possible? Why is it affecting it if SSAA is already on? I did not spend enough time on it to see if it makes the game look even better because i'm too busy right now. To add, I am also using 150% resolution scale, I do not know if this creates an impact as well.
16x SSAA with 4x MSAA AND 1.5x in-engine SSAA? what?
Yes. oced 290's in crossfire. I was under the impression that you can only utilize one AA method, which seems logical as CCC only allows for one choice and not multiple. This is why I want to find out why does adding 4xmsaa in-game affect performance - is it in use, or is it just some confusion?
I would choose 4x MSAA over AA in BF4. I think it looks better and doesn't cause fps to drop like a rock.
