MS SQL select inside an if
jseko
I am attempting to write the below query, but the column doesn't exist in photos table so MS SQL is reporting an error
Code:
if exists (select column_name from INFORMATION_SCHEMA.columns where table_name = 'audio' and column_name = 'aud_length')
	begin
	select * from audio where aud_length = 334
	end
if exists (select column_name from INFORMATION_SCHEMA.columns where table_name = 'photos' and column_name = 'aud_length')
	begin
	select * from photos where aud_length = 334
	end
Right, it's still parsing that query inside the if statement and finding that it's not valid before running the if statement.
Something like this might work.
Code:
	begin
	EXEC sp_executesql @statement = N'select * from audio where aud_length = 334'
	end
	begin
	EXEC sp_executesql @statement = N'select * from photos where aud_length = 334'
	end
Yes, you have to defer the execution past execution preparation because execution preparation includes binding names.
Seems like a pretty goofy thing to do, tho. Why not create the missing column, or create a view that contains the missing column, or ... ?
If you cannot create the missing column then you should make it conditional on a statement which returns the column names in the specified table.
EDIT:
Something like this:
IF EXISTS (select column_name from information_schema.columns
where table_name = 'YourTableName' and column_name ='QuestionableColumn')
