Hey all, I have a question regarding the not-all-so-exciting subject of optical mouses. I recently bought the new MS Intellimouse Explorer 4.0 and while nothing optically has changed according to the specs from the predecessor Explorer 3.0 there appears to have been some changes in the way it responds within WinXP. Since I mainly use it for gaming and I'm running an older MB with only USB 1.1 ports I connect it to the PS/2 port. I have also tweaked the mouse sample rate within XP to 200 but when use Mouse Rate Checker 1.1b to check the sample rate it reads steadily around 90? When I use my old trusty Explorer 3.0 (PS/2) and check with the same sample rate utility I get a value closer to 200 where it supposedly should be. Why is this? has anyone experienced the same phenomenon? Since I have changed the value within XP's own drivers which of the 2 values should I consider the correct one - the one Mouse Rate Checker gives me or should I just trust XP?
I would also like to know if someone can clarify the different sample rates corresponding to the different input interfaces (USB 1.1, USB 2.0 & PS/2)? For example, if i were to buy a newer MB with USB 2.0 - what would the expected top sample rate be for an optical mouse such as the Explorer 4.0? Which is the best for a smooth, lag-free gaming experience? Any help/info is appreciated......
Thanks,
Peter
Thanks,
Peter
