Moving to Hyper-V in Corporate Environment...setup tips
corge
We currently have about 20 or so physical servers that do everything from DNS/DHCP, Exchange, File Servers, SMTP Relay (spam), etc. that we are looking to move to virtual machines using Hyper-V. We're mostly a Microsoft shop and we get huge discounts through MSVL.
I am looking to move to four dual processor quad-core systems each with 24gb of ram. From these systems, I will connect them to two HP gigabit switches and into an iSCSI SAN we are looking to purchase.
My questions are mainly about the storage setup. Should I just create one LUN and then partition off the space for the VMs as we need or should I separate each VM into it's own LUN, etc....?
These are the types of questions I'm looking to address. If you can offer suggestions, or say how your corporate environment is setup using this type of system, that would be great.
Feel free to ask me any questions that you might need answered for more information and I will respond to them.
There are questions about backup and disk intesity from the potential VMs that need to be addressed. If the VM is disk read/ write intensive and needs a robust backup solution, then it should be on its own LUN. However, if there are some VMs that are not as disk intensive, and could share a backup solution then they could probably share a LUN, with the proper partitions. This also depends on how your LUN is setup and in what array, if any.
We run our exchange and a couple database servers each with their own RAID10/1+0 setups to ensure optimal I/O.
DNS. AD, and less intensive servers share a large RAID 5 Lun and our file servers have their own RAID 5 lun as well.
Virtual Machine Manager 2008 R2 makes managing and deploying a snap.
We just run everything on local storage with one huge RAID 6 LUN per server. I'm sure our benchmarks suck, but our users are happy so we're happy.
In a virtualized environment, you'll run out of memory before anything else. You could probably get away with 2 dual quad-core boxes if they had 72gb+ RAM. 24gb on a Hyper-V box is nothing and you'll have massive CPUs sitting idle.
