Moving to a SFF case (space limited) ...
jedolley
I currently run my system in a Lian-Li A05, but am now needing an even smaller case. The spot I have for the case is a cube in an Ikea Expedit bookcase http://www.ikea.com/us/en/catalog/products/80156281. The space allow for 13"W x 13"H x 15.25"D, but there is still about 1-2" of room for depth due to the case not being flush with the wall.
With the in mind I'm currently looking to upgrade my mobo and case. For the mobo, I am leaning towards a GIGABYTE GA-EG45M-UD2H (http://www.newegg.com/Product/Product.aspx?Item=N82E16813128390). As for the case, I'll still a bit stumped.
Originally, I wanted to go with the Ultra Microfly MX6 (best looking imo), but can't seem to find them anymore. I moved on to reading reviews for the XPack2 and for the most part it sounded like a worthy replacement as long as I didn't use the stock PSU. However, I was not in love with the price tag (goes for about $90-$100) and wanted to see what my other options are. I have also considered going with the Shuttle SG45H7 (http://us.shuttle.com/barebone/Models/SG45H7.html), but its on the upper end of what I would like to spend.
I'll be moving in the following parts:
Corsair HX620 PSU
Intel Core 2 Duo E8400
2x2GB DDR2 RAM (don't remember the brand atm)
ATI Radeon HD4870 512MB
WD 640GB HD
Samsung DVD R/RW Burner
Hopefully i've provided enough information so that you guys could toss some suggestions my way in regards to case options.
Thanks,
JD
Yep, there on the side. It's not the smallest SFF case, but the NZXT Rogue is probably my favorite M-ATX case, and it's reasonably priced as well.
I appreciate the suggestions so far. However, the Lian Li won't work due to the side bays (less than 2" clearance for the tray) and the Rogue is just too large in regards to the space i have available.
Thanks,
JD
Yeah I know it was over your size limit. I like the LanBox Lite but I would suggest buying a 3rd 60mm fan for over the slots and I plan to mod my single front 90mm fan into 2 x 80mm or 90mm fans, I may loose my hard drive cage in the process but that is not a big deal.
sry to go a little off topic, but a quick cooling mod I did was as follows
remove the HDD bay
Front of case ---> 80mm fan duct ---> 80 to120mm adapter ----> 120mm fan blowing over cpu side of the mobo. Since there is a fan filter on the front side of the case you dont have to worry about dust either.
dropped temps by 10C and If you get the right fan it will be completely silent.
to the OP,
for that space there aren't too many cases that will fit that space, the NZXT is a little too big. Theres also The Apevia X-Qpack2 and original X-Qpack
http://www.xoxide.com/apevia-xqpack2-window-black.html
SG01 & SG02's come in at 15.5" deep, if you have a couple of inches to spare that should work. Aerocool M-40 would fit too.
Thanks again for the suggestions. I ended up going with the SG-02 for less than $60 after CB + MIR with free shipping. I considered the X-QPACK2, but with the SG-02 being $30-$40 cheaper and arguably better quality, it was an easy decision.
