Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
How big of a case do I need if i wanted to switch my PC's over to server racks in order to fit a full size GPU / Power Supply etc? Is 4U the best size or will a smaller one work?
Depends on the computer. I'm moving my stuff from a Lian-Li PC70 (which re-defines the term spacious), to a 4U rack, and it's a very tight fit. Cooling is especially a concern - I had to get creative to keep temps down. Rack cases tend to have to be loud to achieve the same cooling as a well designed tower.
