I'm running Windows 7 Ultimate x64. Yes, I'm a heavy multi-tasker. I do have a 4GB Turbo Memory mini-PCIe card from another computer that doesn't work anymore.what OS are you using?
if you have that 8GB, do you really use all that RAM?
are you a heavy multitasker?
So what would happen if I set a static 3GB pagefile on the 4GB Turbo Memory mini-PCIe card?Uhmmm...
No. With 8GB of physical RAM in that box, you should set a static page file on whatever actual hard drive you might have in the system of 1GB in size; Windows should barely ever have need for using it with that much physical RAM. Put that 1GB (minimum size/max size) on the VelociRaptor and you'll be better off with improved performance overall.
I mean really, when is fast going to be fast enough?
