Moving into apartment, need computer desk.. specifics..
I'm starting my 2nd year of college, moving into an apartment. I have a big room to myself, and I want to have a studio setup. I'm a pro tools user, and I have a 61-key keyboard. I have a Macbook Pro for audio/music, and my Lian-Li v1000 tower for PC gaming. My display is a Dell 2005fwp, but I might be upgrading to a 2407fwp.
So, now to my question: I need a desk setup to fit all this. I'd like to have my Macbook pro above my synth, and I might get an external keyboard/mouse to control it. Next to it, I'd like to place the PC, with the screen.
Any suggestions for me to check out?
Also, is there a KVM switch that would handle DVI, keyboard, and mouse? I'd like to use my 2407fwp (if I get it) for both my Macbook Pro and PC (when gaming). But I think gaming might be a bit degraded over a KVM..
The DVI aspect of a KVM is expensive, so you'll have to spend upwards of $100 on that for a good one.
As for a desk, check out Ikea. They have the Galant and Frederick. I use the Vika Amon table tops and Vika Curry legs.
Would a flat table work do you think?? They call them "banquet" tables and they are extremely cheap, I got mine at staples. Just make sure you get the wood ones, as the plastic ones are not good for writing on.
I got the 4 foot ones, the smallest they had for a little over 20 bucks. They also have 5 foot and 6 foot models, which might fit your needs better. They all come with metal folding legs, I am sure you have seen the tables I am talking about. If you just need a lot of table space and no drawers or what not, they are an excellent option.
Cheap
Folding
Lightweight
