Moving FreeNAS tower to a rackmount case
Booyaah
I currently have a SFF Silverstone tower case with 8 hotswap drives running FreeNAS. The form factor is Mini-ITX:
http://www.silverstonetek.com/product.php?pid=452&area=en
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157467
I am going to be building out my first rack and I would like to re-use all the existing hardware for my NAS device and just put it in a rackmount case.
The few rackmount cases I have been able to find are 2U and I am not finding where to buy them. Some examples I have found:
http://www.g-alantic.com.tw/11923/ge1205/
http://www.logic-case.com/products/...-35-or-2-x-25-internal-system-drives-sc-2108/
1) The problem with the above 2 is I can't find a reseller that ships to the US. Can anyone recommend me a Mini-ITX compatible rackmount case I can buy?
The other problem I am concerned with is clearance as I am using a HBA card (IBM Serveraid M1015) and the width that the card sticks out is already 3 inches. Plus I need probably another inch for the mini-SAS to STA connector plugs.
http://blog.kihltech.com/wp-content/uploads/2012/10/M1015-front.jpg
2) So should I look into buying some kind of PCI-E 8x compatible riser card? Will I even need one as I thought some rackmount cases already include MiniSAS connectors built into the drive array? Can anyone make some suggestions?
3) Lastly will I need to get a new rackmount compatible PSU? I am currently using this SFF one:
https://www.amazon.com/gp/product/B008VQ2Y4K
Thanks.
Supermicro has a 1U that sounds like it would be 'exactly' what you want.
You will most likely need a new PSU, either specific to that chassis or a certain ATX. (ANTEC makes a nice/cheap one that does front/rear air-flow). You can get those 2Us on Amazon for cheap, add a $40 PSU, your board, and be good...
If you want hot-swap drives, redundant power-supply, etc... it will cost more :)
Most people I know who do racks at home use Supermicro 846 because they're CHEAP on ebay, and you have 24 hot-swap drives with a backplane w/expander (SAS2) <400 to your door, redundant power supplies, etc... can be modded to take 1 ATX, and use 120MM fans if you need it quieter too.
In regards to a 1U, I have a HBA card that is 2.72 inches tall..I don't think that would clear the top of the chassis by default as-is..
They install sideways :confused:
Depending on the 1U that may put a half-height limit, half-length limit, or none at all... etc :)
2U also requires half-height AOCs.
For your first rackmount, consider going with 3u or 4u. It fits normal ATX power supply and full height PCIe cards.
http://www.norcotek.com/product/rpc-3116/
You will need some reverse breakout cables for the drives.
Once comfortable with 3u, you can ramp up the complexity by going 1u with PCIe risers and low profile heatsinks.
There are a lot of 3U and 4U 12-36 bay storage servers from many manufacturers on ebay. You can either buy a complete used server for a good price or just buy the chassis. Norco's and Supermicro's are plentiful.
You may also want to consider buying or building a Storage Pod, they are somewhat inexpensive and come in 30, 45, and 60 drive variants. The Storage Pod is open source so if you have access to a shop with all the right tools, you could build the chassis yourself.
You don't mention what your budget is. How much are you willing to spend?
