Moving for now
Hgradio
Would someome post me a link for a step/step walkthru for settin up WCG, Tnx.
aldamon has one here. Good luck.
That's a nice, straight forward guide by Aldamon and should get you up and running with no problems.
Since WCG is kind of a "different" animal than F@H (works pretty damn smooth after install and config.. actually it can be rather boring because it just works) if you run into any issues or questions about how it all works, post up and someone will get you an answer or try and help.
Welcome to 2nd [H]ardest Folding Team here! It's a small group but with a couple more people kicking in some goodness, I'm pretty confident we can be in the top 50 world wide by this time next year at least. We're @ 82 now, and that's jumped from 96 when I started back in the end of August.
Thanks to the fine contributions from some "new blood" like jws2346, Relic, Flecom, Moogdiesel, Metallicafan, Nomad8u and I'm sure a couple of others that I've failed to mention (no slight to the "oldtimers from this spring like Aldamon, Agrfan etc..) the team seems to be growing some legs and moving up the ranks a bit quicker.
I put it on 2 of the boxes for now. At least I have something to get the cores closer to 100 percent use, hehe.
Nice... you're already showing up on Free-DC Stats. It updates pretty regularly. You should show up @ Hardfolding by tomorrow latest.
Are the stats at worldcommunitygrid.org not correct? There it shows us at #101 as far as a team ranking goes. I have 6 CPU cores going on the grid now. Top 50 here we come. :D
There's two different points systems (WCG points and BOINC points), that's why sometimes things are different. Nomad8u summed it up real good here.
