Moving Data Between HDD's
XSNiper
Is there any efficient way to transfer data between two hardrives? And if so, is it possible to move data from an IDE drive to a SATA?
plug both drives to same pc and just drag and drop is what i do...
ide and sata interfaces dosent really matter...
drag and drop
or use a program like Acronis True image to clone the drive
Also, if I get another drive will I have to install windows on it or will it just add itself in?
(Off topic: I see the bluestorm is popular here.. :rolleyes: )
Your current windows install should see the drive after installation. You'll have to partition it though.
