Moving, Break down my PC?
Operaghost
So I'm moving in a few weeks across states. Started packing up the house and thought I'd ask you guys your opinions. I don't want my PC to get damaged during the move. I'm going to be the one moving everything, no idiot movers throwing my shit around like its garbage or anything.
My question is, should I completely breakdown my PC or is that a little excessive? Or should I just remove the HSF/CPU?
Here are a few pics:
Would you guys be worried about the video card?
I'm thinking, I should just remove the CPU/HSF and the Video Card and call it good.
Opinions?
That's a big CPU cooler, I would remove it. I would blow it out as well. :D
To me, it depends where it's going to be sitting during the drive. If it's in the front or back seat with a seat belt, I would't worry about the Video Card. But if it's going to be in the trunk, then I would remove.
It's not going to hurt anything to remove them and it would be a good time to blow out the fans.
Ya I knew I was due for a cleaning haha.
Oh and it will be in the back of a 22 ft. moving truck, so ya I think I'll remove the vid card and HSF
Thanks for your input mate, cheers.
