Moving around raid
Gibthomacas
I have two 80gb sata hds setup in a raid 0 array. Is it possible to move those drives to another computer and still keep the array intact? Both MBs will be using the same Via raid drivers.
Thanks.
Presuming that the old and new RAID controllers are of the same or compatible BIOSes, the new host should pick up the metadata the old BIOS placed on the drives and read them straight away. Make sure that you connect the drives to the same ports on the new system that they used on the old system, and good luck!
