That isn't much of a factor anymore, certainly not like it used to be. In theory it made a difference, but not in actuality. If you want Vista at the "fastest" part of the drive, then just load Vista on the PC and be done with it. Or, if you have some reason to dual boot, even now, get a second physical drive for Vista.
I'll ignore the cockiness from the rest of your post. You asked for how to do it right, and that's what I gave you. I also tried explaining that you won't really see much of a difference in performance between physical areas of the drive. That, once again, is mainly in theory, and doesn't translate into actual performance gains.I just need advice on doing it [R]ight.
But why would I do that when I have a 320gb hard drive?
Am I on the right forum? I thought I came to [H]ardForums not [E]asyWayOutForums?
If theres a risk, i'll take it, if its difficult, i'll get through it, I just need advice on doing it [R]ight.
So far i'm planning on using a linux live cd called GParted to shrink and move any partition. It can also make backups, so I'll be safe. GParted does mention that my WinXP OS has a registry entry on disk location (i forgot the exact terminology) and that I should delete that part if anything goes wrong, WinXP will rebuild it.
If no one has any information on what i'm trying to do, then I will post my own experience with it so [H]ard members can benefit from.
Wish me luck.
You are wanting to set up a very typical dual boot scenario, plain and simple, and that is what I described for you.
If you had all the answers, and wanted to insist on overcomplicating things, why did you even create the thread in the first place?
If you really wanted to be "[H]ard", we suggest you to get another hard drive and install Vista on it.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Front of drive WinXP" /NOEXECUTE=OPTIN /FASTDETECT /USEPMTIMER
multi(0)disk(0)rdisk(0)partition(3)\WINDOWS="Back of the drive WinXP" /NOEXECUTE=OPTIN /FASTDETECT /USEPMTIMER
Everything else you said ajm786 isn't true or highly debatable, and really we'd need to start a new topic to address each one you mentioned.
provoko said:If I do that, Vista will be at the very end of my drive, the slowest.
There's bound to be subjectiveness in almost any post, but you need to separate fact from your opinion. Everything I stated is certainly not "not true or highly debatable.
On a side note, does your screen handle have anything to do with your perceived attitude to these forums or the members of these forums?
If anything, being at the OUTER edges of the drive is FASTER than the inner, so, if you want to speak in theory, you're wrong there too.
Your statement is the one that merits a new topic to address it, not mine, because the performance difference is NEGLIGIBLE in the real world.
I'm not a hard drive buff but I'd like to know what you guys mean by slower/faster parts of the drive. The total rpm of the drive is dynamic, meaning it spins faster when you hit the inner sectors and slower when you hit the outer sectors (assuming the same bit-density). So how are read/write speeds or even seek times different at all on different tracks?
1) I've read up on Vista boot loader, its more advanced than boot.ini and should work fine in my situation.
2) Partitioning hard drives is what computer users do. Linux users even more so. As for decrease in performance, in my situation, that doesn't apply. I'm not splitting up OS files, games & programs across different partitions, only splitting OSs with their own separate games, programs & games. They'll be completely isolated for my own use no matter how I want to use them. So Vista partition will have nothing to do with WinXP partition and visa versa. No increased fragmentation or wear and tear.
3) Obviously if I lose my hard drive, I lose both my OSes. But the risk of losing my hard drive doesn't double because I have 2 OSes on it (thats silly). Only one is active at one time, so I don't see your point. But besides, I usually back up my computer files.
When I used the words front of my drive, I'm referring to the outer most edge (the fastest); the back refers to the inner most (the slowest). That's why I'd want Vista on the outer edges. I addressed that at the third post of this thread.
I hope you're satisfied that we've talked about what you want to talk about. And I hope I've shown you that it really doesn't matter in my situation.
