MOVED: Max safe voltage for 4890?
Aznboy1993
What is the maximum safe voltage you can increase on the 4890? I've gotten to 975MHz core and 1050MHz memory on 1.35V. I want to try to hit 1000MHz but I can't do it on 1.35V, I can do a BIOS edit to increase the voltage but I was just wondering what is the max safe voltage I can increase to. I've heard 1.4V is good but is that true?
And I also have one question pertaining to BIOS editing using RBE. When you go and edit the voltage do you only change the voltage for the optimal performance clock info (ie. for mine it is clock info 03 and 09) or all of them? Screenshot below...
