Moved cables aroud now display is dead
M4573R
I moved some cables around in my case to make it a lot more clean and improve airflow. Of course when I try and turn it back on, nothing comes up on the display. The GPU fan turns on, but the monitor never gets a signal. Every few seconds or so I hear to faint clicks. Maybe the PSU is trying to shut off or something?
One of the times I tried to turn my computer off by holding down the power button for 10 seconds, and it didn't shut off, it just squeeled until I turned it off with the PSU switch.
I unplugged and plugged my modular cables back in and I switched to a new 6pin x 2 pci express power cable. HDD, and disc drives are unplugged as well as all fans.
Desperate need of help.
EDIT: It's back up and running now, but I'm afraid I have some a cable somewhere that's breaking. Oh well :/
i had the same issue with my television which i thought was dead. it turned out to be a faulty power cord.
You probably shorted something out by mistake and the PSU's short-circuit protection was kicking in (which is why the PSU was shutting off). I suggest you inspect your case wiring and see if you can find any exposed wiring that may have come in contact with the case and caused a short.
I was moving things over to a new case and the same thing happened again. I decided the return the case because things didn't work out and put everything back in my old case hoping it would work again. It took a good 2 hours of unplugging and plugging things in and resetting the cmos before it FINALLY beeped and booted again. I highly suspect my motherboard is dying. Maybe pushing on it in the right spot fixes it :confused:
It can also be your powersupply dying. I had a similar problem with one of my friends computers. I flicked it on and off for hours and it eventually posted, but it would randomly not work when he needed it to be working. I came over and let him have my old PSUs and it fixed the problem. Try borrowing or buying a new PSU. See if that works. Good Luck!
If I can find someone who has a power supply I can try that but I do not have one right now. I had another symptom last night. My computer froze like it tends to do sometimes. It's done it maybe 50 times in the past 6 months to a year and when it freezes the only way to fix it is restarting. I never really thought twice about it because I had no idea what it could be. Last night it froze again, but then didn't post like it's been doing.
I sent my mobo to Asus, and I just got it back. The piece of paper with it said it tested fine... Can these syptoms at all be explained by the processor dying? I would suspect that the computer would shit bricks if the processor wasn't working. Would it still power up and just not boot?
Have you checked to see if your RAM tests ok? Run Memtest on it and see if you get any errors.
Is your mobo shorting to the case, either at one of the mounting holes (standoff or screw is touching a copper trace carrying signal or voltage, either on top or bottom side of mobo, and needs to be insulated by a fiber washer) or at one of the corners (stick rubber bumper feet to the case, close to each corner of the mobo)?
Is it possible that one of your plug-in cards isn't fully seated because it was jiggled when you tidied up the cables or because the mobo isn't quite lined up correctly with the case? The latter can be caused by the mobo being installed slightly too much away from the back of the case or if the standoffs are slightly too tall.
I'd test with all the disk drives and cards disconnected from the power and mobo and with only a low-power graphics card (has no power connectors of its own) installed. Any PCI (not PCI-e) graphics card should be good.
