Move to Core2Duo from Pentium D??
farscapesg1
I've got a Pentium D 3.20 Ghz system at work and we can now order new Dell systems with a E6600 processor for under $1000 (the magical cut-off between operating and capital expenses). Granted, it would only come with 2 GB RAM, but I could order another 2 GB seperately ;)
Would I see much of a difference? I use my system to do testing with Virtual PC 2007, run reporting software, and general office use.
With Virtual PC 2007 you should see some noticable gains in performance.
Otherwise, while the E6600 rapes the Pentium D, it really depends on what you are doing as to whether or not you'd actually notice a real difference between the two.
are the pentium d's presler cores? not that it really matters, but preslers do run cooler and have more cache. like the others have said, you will notice gains with virtual pc 2007. now if those gains are worth the upgrade, that's up to you.
