Move 4 Disk Raid From Expander to Adapter
Has anyone ever had to move a raid set connected to an Intel RES2SV240 expander (which is connected to an LSI 9260-4i) to directly on the raid adapter itself (LSI 9260-4i). Does it seem possible to import the configuration?
Dark Diamond
You should be able to move the set directly to the controller with no issues as long as it is not a dual ported setup, otherwise you need to make a change in the card firmware setup bios.
