I bought an MS Habu mouse 6 months ago, and I love it!!
My computer table is wood with a hard. smooth varnished finished, and I've been using that as my mousepad. The Habu tracks wonderfully on this surface, but I've started to wear through the finish on the table....
So, I've decided that I should buy a mousepad to wear out instead of my table. I want:
-relatively smooth finish (I loved my old RatPad, but the surface is way too rough for the habu)
-THIN! If it sits up too high I get wrist pain. (remember, by current mat is 0.0 MM thick)
-Durable! I'd rather have a hard annodized finsih then a soft plastic or cloth one.
Here are a few I was looking at on NewEgg:
http://www.newegg.com/Product/Product.aspx?Item=N82E16826995025
http://www.newegg.com/Product/Product.aspx?Item=N82E16826999019
http://www.newegg.com/Product/Product.aspx?Item=N82E16826999030
http://www.newegg.com/Product/Product.aspx?Item=N82E16826995019
