Mouse Skipping
XSNiper
I don't know why this has started happening but it is the most annoying issue I have come acrossed. Whenever I try to play most of my games and I try to do some kind of precision movement with the mouse, the crosshair or movement will just skip and be at a new location in a split-second. Its extremely annoying. Anybody have this issue or know how to fix it? I have an MX510 and the rest is in the sig. Also, It might not be related but my videocard runs at at 61-63C at load.
EDIT: I blew out the back of the mouse with some canned air, I also tryed cleaning it with cotton and alcohol
have you checked out the surface your mouse is on i had that same problem turns out it was cus my desk was scratched so i moved the mousea nd it works fine
Try turning off acceleration in your mouse's configuration software and in the games themselves if they have the option..
