Mouse Sensitivity is weird...
jamezzz122
I can't seem to find a right sensitivity for me. The first notch is way to non-sensitive and the 2nd is too much. How come it isn't a gradual thing? Could it be my Logitech drivers being weird?
I also found out today that you had to apply before you "OKed". I thought an OK would confirm and OK it. :D
Hmmm...After testing, I found that my mouse is more sensitive with the mouse options window open. WTF is up with that. :mad:
Fixed. My sensitivity seems to reset once I open the mouse options. Even when I change it, it will stay at the option. I had to enable the mouse icon in the task bar and then click it. For some odd reason, I did that and it fixed it. Do any of you Logitech owners with the drivers installed have problems like this?
EDIT: Actaully the fix was my Ventrilo. For some reason, when I single clicked it the task bar to open it, it was raised my sensiviity until I minimized it. But if I double clicked it, it was fine... :confused:
