Mouse Pad's
I have the fUNC 1030 pad as well and it's by far the best mouse pad I have ever owned. I've had the RatPadz GS and it sucked. Horrible pad; don't buy it.
um i dont think any mouse pad is perfect. i'm on my 2nd func 1030 mouse pad. funny thing was my first one wasnt even messed up too much anyway after playing with it for over 2years. i just thought i would be smart and buff (with the machine grinder) the smooth side a bit well it was a lil too much and it caused a small dent in the pad. i just decided to get a new one. if you play a lot of fps games with quick movements its gonna wear down the pad no matter what, espeically on plastic based pads.
on the plus side i love both surfaces to this mouse pad. i played with the smooth side for years and finally have been playing on the rougher side and its noticably a lot better then the smoother side, go figure? less weird scratching noises from my teflon feet too. not to mention that weird sticking with the smoother side after long use with out cleaning.
this mouse pad is definately a keeper ratpadz is overrated imho.
The Ratpadz GS really let me down! The fUNC 1030 really has been gaming bliss. I'm sure there are better pads out there; but the fUNC really is high quality.
my Xraypad Thunder 8 (with green base) should be here tomarrow .. i will let you know what i think and give a small review
i have yet to purchase one of those ratpadz, i do have a alienware hard mousepad..that i got for LAN party event swag. ...then a few plain mousepads...i only find difference when playing FPS....or a fast paced RPG....to each their own.
