Mouse Feet
HaX
Logitech is a crap face for not supplying any MX Revolution feet.. and within 2- days of purchase the feet on mine are worn out.. What would be the best route for me?.. i was thinking about making some custom feet.. but what material should i use.. everyone seems to enjoy teflon.. but i heard it wears down fast .. so should i use something like a semi-teflon material.. if so..where do i score some of this?
I would use teflon, it wears because of the surface the mouse is used on. I want to know when one of these companies is going to make a mouse that uses ball bearing feet.
wtf?! 2 days?!
Did they make the mouse feet out of butter or something? Exactly how were you using the mouse that within two days you wore out the feet?
i swear to god i wasn't doing to much with the mouse.. it's not all the feet.. it's this one foot in particular that sets the balance off and then makes it rub against the mousepad causing more friction. I'm using a Razerpro mousepad... you can check it out on newegg.. but the surface on the mousepad as very smooth. Don't know what the deal is.. and logitech is being stupid.. so the only way i can figure is if I make my own mouse feet since other companies don't make mouse feet specifically for them
