Mouse causing problems......
diesiel
Alright, when im doing anything (usually browsing) My mouse cursor moves to the upper lef of the screen, you can even kinda say it "Teleports" there, for lack of a better word. it just gets frustrating when i click something and my mouse dissapears up there. Sometimes it dissapears all together for like 5 seconds, then comes back. anyone else have this? What can be causing this?
Ok, have you tried the logitech mouse software? I have a logitech mouse, but I do not use the software. If you use it, you might want to remove it..
If its optical, try cleaning the lense. If its a ball, try cleaning the rollers. If that doesnt work, try a new mousepad.
