Does the 650 pump have to mounted right side up? I think when I mount I may even mount it sideways, I dunno yet but I need to know my options.
Also in the manual it says "In general, we reccommend you mount the pump on the bottom of the case" or something close to that. Why does it matter if you have fluid getting to the pump?
Thanks!
Thanks!
